Question about HP OfficeJet 7310 All-In-One InkJet Printer
How do I set up a wireless printer. I am on a wireless network now. How do I make my printer wireless??
Posted by jhiggins0155 on
ca555
    Scholar:
  • 57 Answers
The HP Officejet 7310 has an optional bluetooth wireless adapter. If you purchased the option, you will need bluetooth connectivity at your computer end. Alternatively, you could purchase a third party wireless adapter.
Other than that, you will need to connect your printer to your router/wireless network then all computers will be able to print wirelessly to it through the router.
Hope this helps.
Posted on Jan 22, 2011
Rommel Alilin
    Guru:
  • HP Master
  • 2,178 Answers
The HP Officejet 7400 series all-in-one uses an internal networking component that supports a wireless network. Detailed instructions on connecting your HP all-in-one to a wireless (802.11b or g) network are included in the Setup and Network Guides that came with your device. I don't think this series does. Read the manual: http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
I have a green Wi-Fi indication of the from of the printer, but it won't print. it says... Lexmark 3600-4600 series 3A82A0_P1
Try to unplug then replug the printer into the power source to reset it. This usually fixes minor communication issues. If problem continues, try to print the wireless network settings to check if your printer is still connected to the same network as your computer(s). Follow the steps in this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If not in the same network, you may need to reset the printer. Follow the steps on how to reset the printer wireless network settings: How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. To reconfigure printer back to your wireless network, refer to this article: How to Install the X4600 Series on Wi-Fi Network - Infrastructure Mode.
Apr 20, 2011 | Lexmark X4690 Wireless InkJet Printer
What do I need to connect the Dell 3100cn printer to a toally wireless network?
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system's networking wizard. If not, then the network must first be established, only then the printer will be made available through that network.
Dec 17, 2010 | Dell 3100cn Laser Printer
How to start up your wireless network
Dec 07, 2010 | Brother MFC-8870dw Wireless Multifunction...
My HP 309 series printer will not stay connected to my wireless network. Can someone help? I end up having to go through wireless network wizard all over again with my WEP password. Very time consuming!
Hello geekgurl !
There are a few things you have to check
When choosing a location for your wireless router, avoid having the following items between the wireless router and wireless devices on the network: long distances, walls, other wireless devices (like cordless phones), and large appliances.
Don't use two wireless routers in your home unless you are very knowledgeable about wireless networking. If your Internet Service Provider (ISP) provides your wireless router as part of their equipment, don't add another wireless router to it or attempt to change the existing settings without the ISP's help or knowledge.
Make the following settings on your wireless router, or verify that they've already been made:
1-Change the manufacturer's default name for the network name (SSID) to something unique.
2-Set the broadcast SSID to "on" or "enable". Note that "on" or "enable" is typically the default setting.
On the printer:
1- See if the wireless indicator lamp is illuminated. Can you turn on the wireless radio from the control panel of the printer?
Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
* Does the Wireless Network Test report indicate trouble?
* Do the reports indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
* Compare the printer's IP address to the gateway IP address. They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
* On some printers, the Network Configuration Page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
* Are there several networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
* Make sure your computer is not connected through a VPN (Virtual Private Network). You cannot access devices on your wireless network while connected to a VPN.
* Disable your operating system's firewall and your security system's firewall and re-test. If this fixes the problem open ports in the firewall.
HP's Network Diagnostic Utility can also be useful
Visit this link
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e013-1&h_keyword=dg-NDU&jumpid=ex_r4155/en/hho/ipg/easy_wireless/network_diag/
Check if theres anyway to set an Static IP (does not change) on your printer instead of a Dynamic Hp (constantly changes)
Good Luck !
Aug 13, 2010 | Office Equipment & Supplies
I can't get it to print wirelessly with my airport express. What do I do? Does Canon Smartbase mp360 not print wirelessly?
You have to setup this printer as a Network printer, the PC using it, must Browse for the PC on the network. Setting up a wireless printer is not a complicated matter to accomplish. It can take as short as five steps to get the whole thing done.
Step #1: The Location of the Wireless Printer.
Since more than one computer would be making use of the wireless printer. It makes sense to figure out the best place to put it. The wireless printer should be set up at a place at home or in the office that is accessible to everyone and where there is ample space for paper, printer ink and other such paraphernalia.
Step #2: Bluetooth or Wi-Fi?
There are two connectivity choices when it comes to setting up a wireless printer, and these two choices are none other than Bluetooth or Wi-Fi. Most new computers and printers nowadays are equipped with either Bluetooth or Wi-Fi capacities, but if not, it is easy to get a wireless card that can be plugged using a USB port. The only difference is that Bluetooth printers has a smaller range than Wi-Fi.
Step #3: Enable Printer Sharing
The server computer’s operating system must be informed that the printer that will be added to its network is a wireless printer. In Windows Vista, this is done by accessing the network settings in the Control Panel and then activating file and printer sharing in the local area network settings.
Step #4: Share the Printer.
The other computers on the network must also be set up for using the wireless printer. To do this in Windows Vista, open the Control Panel in the classic view and then open Printers. Right click on the printer that is going to be shared, and then open Properties. In Properties, check the box that allows the printer to be a shared device.
Step #5: Continuous Troubleshooting
Wireless networks are prone to interruptions, and so it is important for whoever it is that is maintaining the wireless network at home or at the office to keep the connections to the wireless printer active. Nothing is more irritating that setting up a wireless printer and then encountering numerous glitches afterwards.
Mar 05, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Connecting copier machine wireless
Configuration using a wireless computer.
  1. If your computer has wireless capability, you will need to change the wireless settings of your computer to Ad-hoc mode so you can directly connect and configure the printer.
  2. Wireless network terms and concepts
    When you configure the wireless network printer, you must ensure that your wireless network printer is
    configured to match the settings of the existing wireless network. This section provides some of the main
    terms and concepts of these settings, which may be helpful when you configure the wireless network printer.
    SSID (Service Set Identifier) and channels
    You need to configure the SSID and a channel to specify the wireless network you want to connect to.
    SSID
    Each wireless network has its own unique network name and it is technically referred to as SSID or ESSID
    (Extended Service Set Identifier). The SSID is a 32-byte or less value and is assigned to the access point.
    The wireless network devices you want to associate to the wireless network should match the access point.
    The access point and wireless network devices regularly send wireless packets (referred to as a beacon)
    which has the SSID information. When your wireless network device receives a beacon, you can identify the
    wireless network that is close enough for the radio waves to reach your device.
    Channels
    Wireless networks use channels. Each wireless channel is on a different frequency. There are up to 14 different channels that can be used when using a wireless network. However, in many countries the number of channels available are restricted. For further information, see Ethernet wireless network on page 165.
    Authentication and encryption Most wireless networks use some kind of security settings. These security settings define the authentication (how the device identifies itself to the network) and encryption (how the data is encrypted as it is sent on the
    network). If you do not correctly specify these options when you are configuring your Brother wireless device, it will not be able to connect to the wireless network. Therefore care must be taken when configuring these options. Please refer to the information below to see which authentication and encryption methods your Brother wireless device supports.
    Authentication methods
    The Brother printer supports the following methods:
    • Open system
    Wireless devices are allowed access the network without any authentication.
    • Shared key
    A secret pre-determined key is shared by all devices that will access the wireless network.
    The Brother printer uses the WEP keys as the pre-determined key.
  3. I will advise you download this network manual and follow the instructions on chapters 3 and 4.
  4. Network Users Manual - English
Apr 15, 2009 | Brother HL-4070CDW Printer
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
750 people viewed this question
Ekse
efs_perpends
efs_perpends
