Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
HP Officejet 6500 a plus won't print. Every time I press print, it says incorrect paper size. What is wrong?
Posted by pbaker270 on
Michel Smith
  • 1,218 Answers
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issues.
Posted on Nov 19, 2010
  • CISGAL Apr 18, 2011
    how do you resett the IP? My printer is connected to two computers. The USB cable is connected to one computer and the other cables to another computer. I also am using a wireless router. It was working fine this way until I got a bad virus. I had the virus removed but, now this printing issue is happening.
Hp officejet 7000 won't print 6.5 x 10 paper size
Officejet 8620 printed about 400 for me in 16 months then stopped. A few weeks prior to the error msg. that the paper in the tray did not match my document settings another message said it did not recognize any paper in tray including letter size despite there being about 100 sheets. I c alled HP two different days, tried documents on a brand new computer, created a new document. Took two hours total and $20 to be told the printer did not support this paper size. I called them prior to purchase and told them my needs and was told it would accommodate the size. My local techie and I both think the sensors have gone bad in under 2 years as I had been able to print my cards with no issue about 400 times. I called Epson three different times and each tech support person says Epsons can accommodate this.
Aug 08, 2012 | HP Officejet 7000 Wide Format Printer...
HP Officejet 6500 Wireless one day i come home and when i turn on my printer i get a mssg that there is a paper jam so i look and chek that everything is clear so its a flase paper jam then i resart it and...
You may have to get the printhead replaced but first:-
Was the paper jam cleared?[disconnect everything even your PC and re-connect to start afresh]
Clean the printhead by:-
  • Load a plain A4 size paper into paper tray.
  • On the printers control panel,press the setup button.
  • Select tools nad then press OK.
  • Select 'clean printhead and then press OK.
  • After the printhead cleaning,turn the printer off and then on.
Hope this helps.Thanks!
Oct 13, 2011 | HP Officejet 6500 Wireless All-in-One...
Cannot prink anything in black from my HP officejet 6500, have changed cartridge, colour print all ok
Check whether the cartridge's correctly installed and re-install correctly.
  • Load into the printers paper tray a plain A4 sized paper.
  • Select tools and press OK.
  • Now select clean printhead and press OK.
  • After printhead cleaning,turn the printer off and then on again.
Oct 10, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP officejet 6500 keeps giving me two messages 1. load paper when there is already paper and two align cartridges for 7 minutes.
before you on the unit put a single page on a tray then turn it on while initializing it feeds the paper automaticaly then print a sample page after printing put the sample page face down on the scanner then press the scan button then wait till the power on light stop blinking then youre ready now
Aug 09, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500A Plus error message paper size is incorrect. Cannot get anything to print!
On your PC, what is the default setting for this printer. Check in the printer and accessories of Windows.
The paper size might be defaulted to A4 rather than Letter. That mismatch would cause the printer to
error out every time.
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp[ officejet 6500. 1: how do i print dupex ??
I'm afraid your printer is not capable of duplexing automatically, so its a case of reinserting already printed sides the other way up.
secondly the font size is set by the software you print from.
Mar 19, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless just started printing a blank page and bringing up the error message "Paper Mismatch' - been using this for over a year with no probloems
1. Unplug the power cord from the back of the printer. 2. Press and hold the # key and the number 6 and plug the printer back in all at the same time. 3. Release the keys once the printer is already turned on.
If the printer takes the paper but only crumples it. Do the Reset for the 2nd time.
Feb 03, 2011 | HP Officejet 6500 Wireless All-in-One...
Cannot print on regular letter size paper on my HP Officejet 6500A Plus printer. Gives me an error message saying Paper Size Mismatch, but it is the right paper for the print job.
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
How do i know which color ink needs to be repplaced
To print a print quality report
1. Load regular, white, letter-size or A4 paper.
2. Press Setup until you see Print Report
3. Press the right arrow until you see Print Quality Report. Press OK.
Mar 05, 2010 | HP Officejet 6500 Wireless All-in-One...
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
952 people viewed this question
Ekse
efs_perpends
efs_perpends
