this is the report data from maytag for your washer:---
Brand: Maytag---
Country: any--
Model: L4480---
Serial: 564799PA---
This product appears to have been manufactured January of 1985.----
This will help. Thanks please keep updated.please do rate the solution positively
.thank you for using fixya.
Testimonial: "was exactly what i was looking for."
Thank you for your post, debra!
I understand that the front of your Frigidaire washer is rusted. Typically rust is not covered under the warranty and in most cases, the door will more than likely need replacing. Could you please provide me with your model number? You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Once I have that information I can provide additional information for your washer. -Matt
Hello friend, that's a great question!
In order to provide you accurate possibilities of why your washer continues to pause and show 18h, I would need your model number please. You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Thank you and I look forward to your response.-Matt
