20 Most Recent Maytag Maxima EcoConserve Series MHW6000X 27" Front-Load Washer with 5.0 cu. ft. Capacity, 11 Questions & Answers
Maytag maxima codes F06 and E02: Tried doing a spin/rinse/drain on an empty machine. Timer seems tpo be working but cannot hear water filling or barell spin. tried to shut off and door is now locked.
see this causes and fix it. God bless youPOWER/CANCEL press for to cancel the error codes.First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab. Door Switch You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading. Main Control Module / CCU The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace. Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.+fuse thermal +c.breaker
1/25/2019 12:30:23 AM • Maytag Maxima... • Answered on Jan 25, 2019
Why are error codes F01, F06 and E2 showing up?
sounds like its not loading water.. this normally occurs if either your pump filter is obstructed or the inlet pipes filters are..TURN OFF THE POWER SURPLY then turn your water off at the stop valves and get the.. hold a small bolw under the joints when doing this as there will be some water in the pipes. with the pump filter id need to know the model to tell you where there filter is located, if your machine has a small panel at the bottom left of the front then its fairly easy if not the pump is at the back. Click open the front panel you will see a knob similar to that on a mircowave,, turn this gently anticlockwise. ONLYT TURN IT SLOWLY as water will flow out, using a small bowl drain the water out. it will take a few bowl fulls to do this.. when your sure all the water is out fully remove the filter.. and run under a tap to clean of any lint etc, Before replacing put your finger in the outlet you will feel a small fan like device just move it slightly it should rotate freely.. (if not then the pump is jammed or burnt out) when replacing the filter double check for any dirt give it a rub with a sopf cloth and screw back in.. make sure it is in tightly..
9/3/2014 6:52:32 PM • Maytag Maxima... • Answered on Sep 03, 2014
0answers
0answers
0answers
Emergency unlock for Maytag mvw7232hw0?
Unplugging the machine should unlock the lid. Leave it unplugged and try it.
5/11/2024 3:51:47 PM • Maytag Washing... • Answered on May 11, 2024
Maytag Maxima EcoConserve Series MHW6000X 27" Front-Load Washer with 5.0 cu. ft. Capacity, 11 Logo
29 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
error codes f01 f06 e2 showing up
  • Washing Machines
