20 Most Recent Maytag MHWE200XW Washer Questions & Answers
4answers
Maytag 2000 series shows error code f6 e1. How can I fix?
Before spending much time and possible unnecessary work, the E1-F6 code may be nothing more than your bottom cover plate is not in place or missing. Recently was servicing a Maytag 2000 series wash and during the inspecting of the cycles it quit and flashed those codes. I had been testing it WITHOUT the bottom cover plate on. When I went to install it back on the code disappeared. Problem simply solved.
12/11/2020 1:13:09 AM • Maytag MHWE200XW... • Answered on Dec 11, 2020
How to clean the drin filter
If there is enough room put a large adjustable or water pump pliers on the cover,i used the adjustable and put a screwdriver through the hole in the end and very gently applied pressure until in moved, I sprayed a little lube in the space between the cover and housing and it came off much easier then. There was so much debris in the trap and it stinks really bad, a large dish is needed under the cover as a lot of water will come out. Clean out the trap and reassemble using vaseline or grease to help the o ring seal.
1/5/2015 11:41:07 AM • Maytag MHWE200XW... • Answered on Jan 05, 2015
Water leaking out of front of washer
At a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
10/15/2014 1:18:56 PM • Maytag MHWE200XW... • Answered on Oct 15, 2014
We are looking some spare parts how can i contact you
try e spares on the internet
4/3/2014 7:27:22 PM • Maytag MHWE200XW... • Answered on Apr 03, 2014
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.Click this link for tips to reset the lock: Door lockCheck the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
1/22/2013 5:39:12 AM • Maytag MHWE200XW... • Answered on Jan 22, 2013
0answers
Maytag MHWE200XW Washer Logo
40 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag 2000 series shows error code f6
  • Washing Machines
