KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil is spewing into the wash tub during the spin
Oil/grease is spewing into the wash tub during the spin cycles
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 13, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262656
Points
1837
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
2answers
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
I have an Amana LW9203W Washing Machine that is leaking oil into the tub during my wash cycle??? what is the problem...I have polka dotted grease stain on my laundry.
sounds like you have a bad transmission seal and your going to need to replace... there is a seal in the tub between the transmission that could also have failed but the transmission should not be leaking oil regardless on the floor or in the tub so sounds like you are going to need a new transmission and tub seals.... good luck
2helpful
2answers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
1helpful
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
1helpful
Washingmachine tub spins during the wash cycle
If it's a top loader it sounds like the spin pall on the transmission is stuck, which would mean new transmision
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
