Is your
xbox360 having trouble
reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your
Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the
Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact
Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox SupportRegards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internetConnect your Xbox 370 to the internetConnect your Nintendo DSi to the internetConnect your PlayStation 3 to the internetHow to access Windows 7 God ModeTips to clean and speed up your computerHow to configure a wired/wireless home connectionHow to access facebook when it is blocked at schoolExtensive list of device driver links for common electronic devicesKeywordsxbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
The CD I used was good. Actually, the error message my dash unit gives me is "no magazine". I can not find a replacement magazine locally (Houston, TX). Any ideas?
