SOURCE: Water in bean dispenser/grinder
If you look at the bean hopper you will see two screw, loosen this and take off the bean hopper. Now you will see the grinder, you have to take of the adjustment on the side, that plastic on the grinder.
Now you can turn the ring anticlockwise, and take out the middle of the grinder.
Let me know if you wondering about anything
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
SOURCE: Coffee grinder was not grinding.
Yes you are correct one posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Testimonial: "Many thanks. Looks like I need a new grinder motor!"
