Question about Marantz Audio Players & Recorders
I have marantz av receiver amplifier model sr 4600 No power on boot, No power light on standby mode, where can i find marantz service center for mymarantz stereo amplifiere?
Posted by cesario a maza on
5 Related Answers
Anonymous
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Posted on Apr 22, 2008
Anonymous
  • 1894 Answers
SOURCE: Marantz SR7400 AV Surround Receiver
try a hard reset
leave the unit unplugged for one night and then switch it ON
Posted on Oct 07, 2008
Anonymous
  • 86 Answers
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
Posted on Feb 13, 2009
Anonymous
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
Anonymous
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Posted on Apr 06, 2012
When iam turning on its suddenly go to standby in seconds i have checked with service center their is no problem in it how to check the speakers circut or any wire short circut how to solove this
Please disconnect the speakers and try to swicth ON,If it switches ON without going to standby then one of your speakers is faulty.
After disconnecting the speakers and the set stil goes to standby it means one onre of the protection circuits in your system has been activated,check your fan if its rotating,the output ics if are not burnt or shorted.Also check your power supply section.thanks.
Marantz SR-6300 receiver frozen in the CDR mode
It may be weird but it's a small suggestion formerly often occurred at Sony Trinitron TVs building years of 80/90 . maybe the same kind of problem.
A select button internally lingers on the selected matrix usually has priority
2answers
I HAVE A MARANTZ SR880. WHEN I SWITCH IT ON, IT STAYS ON STANDBY MODE. WHEN I SELECT INPUT, IT CLICKS AND THE STANDBY LIGHT FLICKERS. WHAT DO I NEED TO DO?
Possibilities for dry soldering. its a Common problem with this model. Also can happen because of aging . Its tedous procees to open and repair the av receivers. Its better to find expert who can do it for you. i think Marantz authorized service center will not do this as its an out dated model .
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Marantz NR1403 standby mode only
Connect all speakers . Does it start?
If not , you have at least one audio output amplifier failure.
Seek out a Marantz dealer to help you get a tech
Marantz SR4003 flashing red standby mode
Sir my marantz sr 4003 AV Receiver standby red light blinking last time surround mode and exit button pressed two times problem solved now two days on words again same problem please give me suggestions
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
5helpful
3answers
iskender
2answers
Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
9helpful
4answers
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
