20 Most Recent Marantz SR5004 Questions & Answers
Marantz SR5004: display says 7.1 CH input source
Look on your remote. There is a button top right that says 7.1. Hit it. Reselect input and surround and you should be good to go.
12/31/2021 1:39:06 PM • Marantz SR5004 • Answered on Dec 31, 2021
2answers
My sr5004 marantz is in standby with the indicator is blinking on the front how do i get ride of it
Power the unit down and remove all cables. If it still blinks when you power back on, you probably have a PS failure. I could not locate any fuses or circuit breakers on mine and had to return for service. There is a factory reset that can be performed by pressing and holding the surround mode and clear buttons on the front panel at the same time for 3 seconds.
6/26/2015 12:35:00 AM • Marantz SR5004 • Answered on Jun 26, 2015
2answers
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination. Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
6/26/2015 12:33:33 AM • Marantz SR5004 • Answered on Jun 26, 2015
My marantz sr5004 is flashing the standby light and wont switch on
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
12/1/2012 5:25:59 AM • Marantz SR5004 • Answered on Dec 01, 2012
0answers
Marantz zone 2
Be the first to answer 5/20/2012 7:49:16 PM • Marantz SR5004 • Posted on May 20, 2012Be the first to answer
What is the Best way to connect a Wii to the Marantz SR5004
the best soution is to connect them.hope this helps.kind regards,KJ
12/19/2011 4:44:11 PM • Marantz SR5004 • Answered on Dec 19, 2011
Standby ligth blinking
It is possible that the system is on protect due to an error . So it is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
6/16/2011 6:40:42 AM • Marantz SR5004 • Answered on Jun 16, 2011
New tv, new marantz sr5004, hdmi cable- no sound
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
10/23/2010 12:12:49 AM • Marantz SR5004 • Answered on Oct 23, 2010
Is the Marantz SR68 an FM tuner please?
No, it is a Surround Sound Receiver for taking television signal, or a signal from another device and amplifying it to multiple speakers.. https://www.google.com/search?q=Marantz+SR+68 ..
2/21/2023 4:20:06 AM • Marantz Audio... • Answered on Feb 21, 2023
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
2/12/2023 3:15:35 PM • Marantz Audio... • Answered on Feb 12, 2023
The poweramp of my Marantz SR6004 AV Surrount Receiver only turns on after about 3 minutes.
Parece que el problema puede estar relacionado con la fuente de alimentaci?n de su dispositivo. Es posible que desee verificar si la fuente de alimentaci?n proporciona el voltaje y el amperaje correctos. Adem?s, es posible que desee verificar si hay conexiones sueltas que puedan estar causando una interrupci?n en la fuente de alimentaci?n. Tambi?n puede intentar restablecer el dispositivo a su configuraci?n de f?brica para ver si eso resuelve el problema. Si estas sugerencias no funcionan, es posible que deba consultar el manual para obtener pasos de soluci?n de problemas m?s detallados o ponerse en contacto con un t?cnico calificado para obtener ayuda.
1/6/2023 9:04:51 AM • Marantz Audio... • Answered on Jan 06, 2023
Marantz SR5004 Logo
23 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
marantz sr5004 flashing standby light
  • Audio Players & Recorders
