Marantz SR 6007 AV Network Receiver Logo
A
Anonymous Posted on May 12, 2016
When iam turning on its suddenly go to standby in seconds i have checked with service center their is no problem in it how to check the speakers circut or any wire short circut how to solove this
ibrahim
Level 1:
Habit-Forming:
New Friend:
  • Contributor 19 Answers
  • Posted on May 12, 2016
ibrahim
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
19
Questions
8
Helped
2510
Points
31
Please disconnect the speakers and try to swicth ON,If it switches ON without going to standby then one of your speakers is faulty.
After disconnecting the speakers and the set stil goes to standby it means one onre of the protection circuits in your system has been activated,check your fan if its rotating,the output ics if are not burnt or shorted.Also check your power supply section.thanks.
2answers
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
When i plug in the standby light come on but the tv wont turn on after about 30 seconds the standby light goes off and i have to unplug it and wait a few seconds wont turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Turns off after about 20 seconds..
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Grundig blue screen then black after 5 seconds
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
My denon AVR 681 turns on for a few seconds then immediately goes into standby, attempted to reset by holding in on speaker a and b as instructed with no luck, any other suggestions? This unit is a few...
A very obvious evidence shows there is a DC coming out of the speaker terminals.
https://www.hifiengine.com/manual_library/denon/avr-681.shtml?_e_pi_=7%2CPAGE_ID10%2C1610027943
first download service manual.
check any DC voltages developed at the speaker
output terminals. Differential amps got damaged ,shorted, are common. Check for any shorted transistors of pre-amp stage which amplifies voltage.
Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
2answers
Standby Problem
No, I think you have a bias problem in the audio output circuit of this receiver. There is really not a lot a user can do to fix this unless you have the electronic know how and know how to trouble shoot solid state electronics. Good Luck
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
