20 Most Recent
Marantz SR4002 Questions & Answers
Marantz SR4003 flashing red standby mode
Sir my marantz sr 4003 AV Receiver standby red light blinking last time surround mode and exit button pressed two times problem solved now two days on words again same problem please give me suggestions
No sound to back channel speakers
The disc menu and sometimes the box will say if has 7.1 sound. Look under the Audio options on the disc menu.
Only your receiver will convert 5.1 sound to 7.1 if it can do so. The disc will either have the option for 7.1 or not.
Marrantz sr4002 blinking stand-by button
If you've checked all your speaker connections and there is no short, reset the amp by holding down the "S. Speaker B", "ATT", and "EXIT" buttons for three seconds.
Standby light blinking
if you have the blinking led problem on your SR4002 receiver, it is in protect / safe mode 1- turn on you receiver2- hold 'S speaker B' + 'ATT' + 'exit' buttons at the same time for 3 seconds3- it should turn back on normally
Marantz sr4002 - Power light
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
HI. I have a 4002
Have you chnaged the power leads and connected the equipment to different wall power outlets, expecially the suvwoofer.
If so you could have a earthloop problem.
To overcome earthloop problems, connect all your equipment to a single power mains outlet using a power board/strip.
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
