Posted on Feb 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No output regardless of input- cd, fm, am aux.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Feb 13, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2775343
Points
24828
Is it new to you?
Make sure there are jumpers connecting the rear like in the picture.
http://www.soriaudio.com/zboard/view.php?id=m_2nd&page=3&sn1=&divpage=11&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=193214
UN-select anything to do with Tape or Muting.
1helpful
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
How do i get the bluetooth to work on an bmwx 4745
This machine has no Bluetooth:
BMWX-4745
7"
Digital Two DIN In-Dash Widescreen/Touch Screen Monitor, AM/FM Radio, iPod Ready, DVD/CD/MP3/MP4/WMA Player, USB Port/SD Card Slot, Aux, Fully Motorized Front Panel
• Clock Display
• Electronic Audio Control
• High Power Speaker Output
• Rear Audio/Video RCA Input
• Front Aux Input (Audio/Video)
• Video RCA Output
• Front/Rear Preamp Output
• Subwoofer RCA Output
• Rear Camera Input
• Auto Antenna Control
• Auto Handbrake Control
• Full Function Remote Control
Two Din Motorized
1helpful
2answers
How do i hook up a ipod to the cd player
Go here:
http://www.crutchfield.com/S-j3EX2WZGpxL/p_113MP232/Kenwood-KDC-MP232.html?tab=features_and_specs
You can download the manual and specifications.
1helpful
2answers
Is it possible to connect turntables and mixer to Acoustic Wave Music System 2 through the Aux, and simultaneously play a backing CD so that both can be heard? Eg, scratching vinyl over a hip hop beats CD.
Yes.
A traditional turntable requires a preamp inline with it to PRE amplify the minute signal produced by it's cartridge. Most setero receivers and preamps have Phono connection and internal preamplification strictly for that purpose. Many mixers out there have a Phono section or two, too, so your mixer will determine what you can do with vinyl.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
The mixer can send its output to the Aux input on the AWMS-2.
If you have only the internal CD player I don't think you will be able to do what you want. Reason: the AWMS-2 doesn't have a traditional Tape Monitor circuit which would allow its own internal program (including AM/FM) to exit to your mixer and come back in via the AUX. Selecting AUX disables its output. Thgis is to preevent a potential feedback loop. The AWMS wasn't designed for people who want or can control complexity in their listening.
If you have the external 5-CD changer or another CD source, you would be able to run all that through the mixer prior to its entry into the AWMS-2.
1helpful
Can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Yamaha HTR-6030
There's possibly some leakage internally.
Do you have a normal (Playback only) CD player on the MD/CD-R input? It's supposed to support a RECORDING device as you can see by the OUT (REC) connections. A recorder would have shielded cables there and maybe the circuitry is such that ungrounded/unshielded output to the recorder allows a leak of the FM, which is developed inside the receiver.
Since you know that FM is leaking why don't you just selct some other idle source before selecting MD/CD-R? Have you also heard, say, the DVD, if it is playing when you select MD/CD-R?
Or skip the analog route entirelzy and run digital cables from your CD player to one of the Digital Inputs, if you have a spare one. They're all functionally the same. I guarantee the FM won't get in that way.
Aux inputs
chek your wiring and your speaker.nad of coars the sound output of your dvd
36helpful
8answers
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
1helpful
3answers
Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
