Marantz Nr1402 Av Receiver Logo
Question about Marantz Nr1402 Av Receiver
Marantz NR1402 AV receiver Going to standby Mode
I have a brand new Marantz NR1402 AV receiver. The receiver is going to standby mode after 10 secs. I am using Wharfedale Diamond 10.1 as front channel, Dimond CS as centre channel and Bose acoustimass 5 as surround speakers. The front channel is connected to a Pioneer Integrated Amp throug the pre-out of the receiver. The front and centre chanel speakers are 6 ohms while the surround speaker is 8 ohms. What could be the problem.
Posted by Perry Joseph on
2answers
I HAVE A MARANTZ SR880. WHEN I SWITCH IT ON, IT STAYS ON STANDBY MODE. WHEN I SELECT INPUT, IT CLICKS AND THE STANDBY LIGHT FLICKERS. WHAT DO I NEED TO DO?
Possibilities for dry soldering. its a Common problem with this model. Also can happen because of aging . Its tedous procees to open and repair the av receivers. Its better to find expert who can do it for you. i think Marantz authorized service center will not do this as its an out dated model .
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Marantz NR1403 standby mode only
Connect all speakers . Does it start?
If not , you have at least one audio output amplifier failure.
Seek out a Marantz dealer to help you get a tech
2answers
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Marantz SR4003 flashing red standby mode
Sir my marantz sr 4003 AV Receiver standby red light blinking last time surround mode and exit button pressed two times problem solved now two days on words again same problem please give me suggestions
1helpful
2answers
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
When I play my dvd thur the receiver Marnatz NR1402 It makes the picture flash but if I disconnet it from the receiver it does not...what is wrong with his receiver?
I have had this problem.......Try hooking the receiver up to a different plug or power strip.....It could be having electrical feedback.
1helpful
Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
Hi, my Marantz sr8001 is on standby mode, can you show me how to reset standby mode. Thanks
Mine is doing the exact same thing! All I want to do is get it OUT of standby mode!
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
