When I light it up it opens in the cdr mode. It stays that until I put it in standby mode.
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
SOURCE: Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
