The lid is delicate and may have lost a point on one of its corners. Order a replacement. This has happened to me twice over the years and both times this resolved it. You can first experiment by applying very gentle pressure from the point of a small, sharp knife at one of the spots where those points of the lid clicks in (first examine the lid to see if there may be a subtle change/chip in one of the points).
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
SOURCE: machine will not grind beans.
That error message will also appear if the coffee grind is too fine.
SOURCE: Sony Bean 1gb "Format Error"
I have the solution. Push the menu button (the one ne with the file folder) until "search" is displayed. push the down arrow key on the jog button,10 times, until "advanced menu" is displayed. Pushe the right button on the jog until "format" is displayed. Use the jog buttons until "format ok" is displayed. Then push the play button and the problem is sorted. Good luck.
SOURCE: how to turn off the bean mp3 player
just stop playing music and slide it on to hold and leave it for around 10 seconds it will then turn off
SOURCE: Need instructions for a Theodore Bean Baby Carrier
go to your local reatail store and find the same item that you have or the same brand, and ask the store if you could get a copy of the manual, and they will be able to get that for you. or you can call the company and get the manual for the item that you have
I will send you a
great how-to guide that instructs you on how to properly clean your bean bag
chair. One's with removable covers are
easiest to clean.
http://www.overstock.com/guides/how-to-clean-a-bean-bag-chair
