SOURCE: Samsung clx-3160 won't print
On the printer. Check under menu > Network> TCP/IP> If it comes up Static then hit the ok button to check the static address it gives you (should be 192.168.1.xxx). Make sure you don't change anything (use the back button to exit). Just copy it down. If it comes up DHCP then it is set up to obtain an address automatically. On your PC in Windows XP, Go to printers/faxes, right click the Samsung CLX3160FN and click on Properties. Click on the Ports tab. Check to see that there is a check mark next to standard TCP/IP it should say Samsung CLX-3160FN next to it (or not) (the name is only used to identify the port from others) and higlight it. Click on Configure Port. IF YOUR PRINTER WAS SET TO STATIC then the TCP/IP address here should match the address you copied from the printer. If your printer is set to DHCP but can't communicate with the PC you may want to set your printer to Static and set the TCP/IP address manually. you have to use 192.168.1 the last three digits should be higher than 100 and lower than 200. I have mine set to 192.168.1.104 and it is working fine. You just have to make sure that the numbers on the printer and the numbers under your port setup in Windows are the same. IMPORTANT: THIS ADDRESS HAS TO REMAIN UNIQUE TO YOUR CLX-3160FN AND MUST NOT BE DUPLICATED IN ANY OTHER DEVICE ON THE NETWORK OR IT WILL CONFLICT. IF THAT HAPPENS RAISE THE LAST THREE DIGITS OF THE ADDRESS TO STAY AWAY FROM ADDRESSES USED BY OTHER DEVICES. I have an HP laserjet and a print server with an Epson Photosmart on it also and I had address conflicts. I set them all on static with a unique address for each and now they don't collide and work fine. If you have to, you can set up a new port for your printer under windows. Same as above just click on add new port and follow the instructions. Again make sure that you use the same port number you have the printer set up under Static. I hope this helps.
Also check on these:
1) try using a different port on your router (sometimes ports go bad) If it is, get a new router.
2) try using a new ethernet cable, make sure it is Cat 6. For some reason these high end MF like that better.
3) Check the lights on the back of the printer next to the ethernet connection. You should have a yellow light and a green light. The green light should be blinking when it is communicating on the network. The yellow light should stay solid to show a connection.
4) Make sure your ethernet card on the PC is activated. Control Panel> Network Connections - depending on your machine there should be a local area connection that shows a couple of monitors with a tee connector and a cable with a lock going from one to the other. If it is dissabled it would have a red X accross the cable. If it does, right click on it and click on enable.
Good Luck
SOURCE: My Samsung CLX-6200 Network MFP printer prints but does not scan
Hmm Tricky,
You could try temporaily disabling the windows firewall, and any anti-virus firewalls to see if they are blocking communications to the scanner.
(Please rate my answer thanks :)
SOURCE: Brand new Samsung multi-function CLX-3175FN prints
Have you done a print head alignment? If yes, and that did not fix it, take it back before you warranty runs out. Most modern day electronic devices work perfect but when they don't they also do it perfectly.
The only things you can do is print head alignment and making sure when you installed those nice new print cartridges that they are pushed in all the way. To try and test anything else will cost money and since this is a brand new device it is best returned.
