20 Most Recent
Samsung LASER Printer Questions & Answers
I have samsung laser printer SCX4300, my printer
Hi!
if you refilled your toner then it is best to buy a chip for it. The price is not so hi, maybe around $5.
When I refill the toner I put a new chip and I save nerves cells :-)
I tried out a lot of software but all of them was full with viruses...
My Samsung CLX-3180 printer is
The printer might be out of one of the colors of toner. Most color laser printers will revert to black and white when either the cyan, magenta, or yellow toners run out. Check to see if any are empty or near empty. Also check the settings on the printer and your computer to make sure that it is set to print in color.
Samsung 1915 printer: the red light with the
1. A minor error
has occurred and the machine is waiting for the error to be cleared. When
the problem is cleared, the machine resumes.
or
2.Small amount of toner is left in the cartridge. The
estimated cartridge life[
a] of toner
is close. Prepare a new cartridge for replacement. You
may temporarily increase the printing quality by redistributing
the toner.
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
