Question about Samsung LASER Printer
My clx 3180 samsung colour laser will only print in black and white? how do i make it print in colour
Posted by akjhein on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: My Samsung CLX-2160N will not print black and
See answer posted by Loki
Posted on Jul 07, 2009
Anonymous
  • 10 Answers
SOURCE: laser printer samsung clx260 prints pale black
please check cartridge and your printer settings.
Posted on Dec 06, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Posted on Dec 28, 2009
dgsturt
  • 1705 Answers
SOURCE: My Samsung CLX-3160FN has stopped printing colour.
You need to check your document print settings on your PC. Drill through the printer properties menu until you get to the colour settings. At a guess you currently have it set to "Greyscale" rather than colour or auto.
Posted on May 03, 2010
Anonymous
  • 49 Answers
SOURCE: my Samsung CLX-3180 printer is
The printer might be out of one of the colors of toner. Most color laser printers will revert to black and white when either the cyan, magenta, or yellow toners run out. Check to see if any are empty or near empty. Also check the settings on the printer and your computer to make sure that it is set to print in color.
Posted on Jul 28, 2011
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
[email protected]
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Why can't I just print in black and white even though I am out of the Cyan toner for the Samsung CLX-3175FN
Dear user,
You have to select monochrome print settings first. go to properties of your printer and choose the tab where you get to select between B&W and color.
Aug 22, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3180 Series calibration
If it's virtually brand new, why can you not invoke the warranty to demand a replacement?
Jun 09, 2012 | Samsung Office Equipment & Supplies
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
My Samsung CLX-3180 printer is only printing in Black and white
Jul 28, 2011 | Samsung LASER Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
How to set black & white print as defult for CLX-3175
can be set in windows, just like other printers
Goto start, printers, select samsung printer, right mousebutton on samsung printer, select preferences, graphics, colourmodus gray.
(translated my Dutch menu to English)
In default my printer prints BW, if i need colour prints, same menu youll get in any program by using printsetup, set it to colour and send your printorder.
Sep 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My Samsung CLX-3160FN has stopped printing colour. I have changed all the cartridges and it will copy in colour, but prints in black and white.
May 03, 2010 | Samsung CLX 3160fn All-In-One Printer
My samsung clx-3160 colour laser printer does not print very well.all prints are barely neglible and now most times no print or characters appear.I have installed new ink cartridges.Please advise.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Jun 29, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung LASER Printer Logo
Top Samsung Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
