20 Most Recent
Samsung CLP-610ND + Demo Laser Printer Questions & Answers
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
11/6/2021 3:47:26 PM •
Samsung...
Answered
on Nov 06, 2021
Samsung clp-610 has an error code of
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
9/12/2012 2:44:45 AM •
Samsung...
Answered
on Sep 12, 2012
There is an "ADC
Welcome to Fixya. ADC Slope Error Cycle Power means that The temperature slope for ADC (Analog to DigitalConverter) detects the value out of the normal range. This is a Service Call Error of
CLP-610ND
Solution: This problem can be fixed by just Power Cycle. However, if the problem persists, contact the service representatives.
You can also refer to the user manual below.
Samsung CLP-610ND User Manual
Thanks for using Fixya.
5/19/2011 8:57:49 PM •
Samsung...
Answered
on May 19, 2011
All printed pages come out with random "V" type
Check to see if there's anything stuck onto the fuser rollers. It sounds as if there may be some residue dirt that prevents the fuser to do its job. It may be that someone tried to print on a self-adhesive paper that was not meant to go through laser printers, and somehow a triangular shape got stuck on the rollers.
On the other hand, if this V shape is just a wrinkle that's different on every printout but preserves the general V shape, then you may be looking at the paper guidance plastic "fingers" inside the paper tray. See that the paper is freely movable and it's not pressed too hard. Also, see that you don't use lighter paper than 80g/m2, although printers say they can handle lighter paper, 80-120g/m2 is still the best thickness for lasers.
If you found this post informative and helpful please vote for it with a Thumb Up. Thank you.
1/18/2011 11:03:51 PM •
Samsung...
Answered
on Jan 18, 2011
Trying to print labels, but
MP is the tray in the front it looks like a door on the front. When you open it it turns into a tray for you to put the label paper on.
11/19/2010 7:40:25 PM •
Samsung...
Answered
on Nov 19, 2010
