SOURCE: ON Samsung SCX 4216 Error: Paper
Hello! Welcome to FixYa
Paper jam means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper
jam. There will be tiny piece of paper, or a lump of dust, inside those
sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
SOURCE: printer appears fine, but it makes a noise and
does the paper get picked up.if yes fuser faulty.if no pickup roller and seperation pads need replacing.
SOURCE: samsung scx 4100 just decided
Its a mechanical problem.
The best solution for that is to call a service technician nearest to your place.
SOURCE: Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
firmware
