20 Most Recent
Samsung Clp415nw Color Laser Printer Questions & Answers
Error #a1-4111 on a sasung printer/copier model CLX-4195Fw
Hi, it's Actuator Motor Error, check and ensure that all orange plastic cover has removed from the toners. If cover has been removed, probably you need to check the solenoid on the top after you have remove the right side cover. If still persist, you need to replace the main board.
#a1-4111?
Hi, it's the Actuator Motor Error. You need to removed the right cover and locate a solenoid on the top, and check if it's working fine. Otherwise need to replace the main board.
A1-4111
I used samsung clp-415nw in China,the input power I have change to 110v ,but it has error #a1-4111 call for sevice.How i can do buy myself. tks!
Samsung M2070 printer frozen and displays wait image
The printer could be configured incorrectly or not properly been set up . Check the settings and the preferences to be able to print and make sure that all of the print settings are all correct. The printer driver might be not properly installed.
