SOURCE: samsung CLX-3175FN printer instructions - How do
3175fn is acolor printer. if you want to set only grey or black only print. you have to go to printers & fax. select the printer right click properties and go to color and set as gery or black only print.
SOURCE: clx 3175fn says "toner low" and won't print. but I
If is attempting to print the documents remove the cartridges and check to make sure they were properly installed. Make sure that the tape was removed that covers the ink and that the cartridges "click" into place when installed.
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
SOURCE: Samsung CLX-3175FN printer only prints VERY faint
Faint prints with Laser Printer usually occurs when the drum is full with the wasted ink (toner power) or when the Fuser Unit is not working correctly. First of all try cleaning the Drum and remove the wasted toner power. There should be an opening on one of the end of the drum. In some cases, it needs to be disassembled to remove the wasted inks.
Also remove the fuser unit and clean the unit. Please handle it with care and never clean it when it's hot/warm. Only do this, after the printer is left turned off for about half an hour.
If nothing is helpful, try with another/new drum or fuser, that will help you get to find out the exact cause of the problem.
Good Luck.
Thanks for using FixYa.
The life of the toner cartridge yield depends on the amount of toner that print jobs require. The actual number may also be different depending on the print density of the pages you print on, and the number of pages may be affected by operating environment, printing interval, media type, and media size.
If you print a lot of graphics, you may need to change the cartridge.
The machine uses four colors and has a different toner cartridge for each one:
yellow (Y), magenta (M), cyan (C), and black (K).
• The status LED and the toner-related message on the display indicates which each individual toner cartridge should be replaced.
Trust this helps. Please vote. :)
