These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
