Question about Polaroid TDX-01930B 19 in. LCD HDTV
I cannot hear any sound out of my Polaroid TDX-01930B television.
Posted by derekwilber on
    Top Expert:
  • Polaroid Master
  • 76,466 Answers
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
Posted on May 06, 2011
  • David Chester
    David Chester Jan 04, 2014
    this answer didn't address my question.
I got a class to transformer power cord 120v AC 60hz 12 watt input output is 12 volt DC 6.0 what will that work on my Polaroid tDX 1930 B
Check Amperage of your Polaroidd and the power adapter. Same voltage but higher amperage might fry your Polaroid.
If won't work, you might buy one for Amazon
UpBright 12V AC Adapter For Polaroid TDX 01930B TV DVD Combo Charger Power...
May 12, 2015 | Computers & Internet
My tv shows the on light and the screen is on then it just turns off
you have to change in the main power module some capacitors that are jammed, see if there are some almost exploded.
May 27, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I need a tv code
YOU CAN GET A CODE , MANUAL OR REPAIR MANUAL AT WWW.TVPARTSANDMANUALS.COM
Jan 12, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
Missing power cord polaroid tdx01930b tv
I am not sure what you are trying to ask.
If you need to get a new one, try contacting the manufacturer using the link below. If it uses the same kind of cord as a computer power supply you can get that at radioshack.
http://www.polaroid.com/contact
Jan 29, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
Tv powers on then immediatly turns off
There are 2 capacitors on the power supply rated at 450 volts and 10uf, replace them and it will work again.
Jul 04, 2009 | Polaroid TDX-01930B 19 in. LCD HDTV
DVD Player Problem
Call Polariod and they will send an update cd to solve the problem.
Mar 15, 2009 | Polaroid TDX-01930B 19 in. LCD HDTV
Lost power cord
You should try matching up the amperage (A) and voltage (12V) with a universal adapter. You can find at radio shack or walmart. Make sure you get as close to possible to correct amps, anything more than the correct amps can fry your tv. Volts doesn't have to be exact
Dec 13, 2008 | Polaroid TDX-01930B 19 in. LCD HDTV
Polaroid TDX-01930B 19 in. LCD HDTV Logo
2,165 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
