Turn the radio on.
Hold down the volume knob for 3 seconds.
The display will come up Volume Setting
Rotate the volume know clockwise until the display switches to time setting.
Push the volume knob.
Rotate the volume knob to select the hour
Push the knob
Rotate the volume knob to select the minute.
Push the knob.
Done.
UPDATE IX35 TIME ON SATNAV AUDIO SYSTEM
If your IX35 has an inbuilt satnav system you won't be able to change the time in the clock section.
You will need to open satnav and select more options, now select settings and arrow down until you see regional option.
select regional option and then select time zone.
If your time is wrong you will need to unselect use auto update time and then manually set the time using GMT (Greenwich Mean Time). If you aren't sure what your GMT time is you will need to Google it.
Once you have done this your time should display correctly.
You can select the daylight savings time feature but I've found this can be out too so I just update it manually when it changes.
