Question about Bunn CWTF15-TC
Adjust bunn coffee maker water level - Bunn CWTF15-TC
Inky Fingers
  • 705 Answers
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
adjust bunn coffee maker water level - 24680777-5fyec3sitw1tjv0jktfwuexb-3-0.jpg
Posted on Nov 25, 2014
5 Related Answers
Anonymous
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: MY Bunn coffee maker GRX leaks .
Complain loudly to Bunn, they fixed mine for free.
Posted on Dec 09, 2009
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Hot water faucet adjustment?
The Axiom uses a water level probe to keep the heater tank filled with water at a set level. The hot water facet takes water directly from the top of the tank. It's gravity fed with only the weight of the top portion of the water (the hottest area) to flow into the faucet. It is possible that your faucet 'Boot' or spring is bad and needs replacement. But it's designed to give you a single cup of hot water. Do not expect to fill a pot (or large french press) with this faucet.
* Call your vendor for service.
Aloha, ukeboy57
(the parts manual) https://catalog.bunn.com/public/docs/39131.0000/E17/01/000/39131.0000.pdf
Apr 03, 2014 | Bunn AXIOM AXIOM-DV-APS Coffee Maker
How do i adjust the water level on my Axiom Bunn coffee maker? It only brews about a half of a pot.
Remove the front panel there are instructions on increasing the water level.
Feb 18, 2011 | Bunn AXIOM-35-3
Coffee maker will not shut off water supply, will not adjust water setting.
Sounds like the solenoid or the liquid level control board is not working.
Sep 23, 2010 | Bunn CWTF15-TC
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Aug 14, 2009 | Bunn NHB Coffee Maker
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Water Level Has Dropped
you may need to reset the dispense time. open the front panel and read the instruction on the panel itself. make sure the switch is in the "lock" position when you are done.
May 14, 2008 | Bunn CDBCF 15 APS Coffee Maker
Bunn CWTF15-TC Logo
2,584 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
