No other buttons will respond only the volume button...then it goes right back to VCR display
Unless it has some kind of "child lock" mode, in which case you should see the manual about how to reset it. It sounds to me that there is a fault on the microprocessor that controls the functions. It's not something that could be solved other than by an engineer.
Look around for a service centre for Sherwood on the net. Richer Sounds in the UK sold a lot of these, they might be able to help you.
SOURCE: Sherwood RX-4105 Receiver will not stay on
you denon guys go into your manuel and look-up protection mode and how to reset your recievers oh did you use the adussey microphone to set it up it will make a world of difference in sound oh i own a home theatyer store in michigan called theaterxtreme 1-248-456-1800 my name is terry
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
SOURCE: sherwood rx4103
i have the same problem with mine... its anoying is there like a reset on this item?
SOURCE: SHERWOOD RECEIVER 6108. I
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech. Check for loose speaker connections as a root cause for intermittent shutdown.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
