Question about Onkyo Audio Players & Recorders
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Posted by Brendan Nugent on
Onkyo USA
  • Official Brand Answer
  • 333 Answers
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
Posted on Jul 31, 2015
5 Related Answers
Michael Borelli
  • 979 Answers
SOURCE: Rear left channel not working on Onkyo NR801
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Posted on Oct 31, 2007
Anonymous
SOURCE: Subwoofer ... it is hooked up, but no sound
I found a manual online, and learned that there is a speaker set-up procedure on this Onkyo model ... so when it got to the subwoofer set-up, I simply went from "subwoofer off" to "subwoofer on"
Posted on Jul 27, 2008
Anonymous
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
Anonymous
  • 59 Answers
SOURCE: Describe your Onkyo TX-SR875 7.1 Channels Receiver
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Posted on Nov 22, 2009
Keith Marks
  • 478 Answers
SOURCE: Onkyo 501 Onkyo Receiver no sound out of right
if you are good at tinkering then you can pulol the top of the receiver and check the fuses on the board to make sure that they did not blow if not then it would be wise to take it to a repair shop to have your receiver checked out and serviced
Posted on Dec 12, 2009
I am not getting sound from the left speaker channels (A and B) on the onkyo tx-v940. I tested wires and switched speakers.
Hi, Are all of the left side speakers out? If they are the receiver would need to be serviced. Thank you, Onkyo USA
Oct 23, 2016 | Onkyo TX-V940 Receiver
No sound from my new (refurb) onkyo receiver
First of all, be sure the volume is down fairly low so that you don't blow the speakers or the unit itself if and when the sound suddenly comes back. I've repaired many units whose owners turned them way way up to try to hear something, then flipped off a tape monitor or mute switch and got blasted. No sound with any input? (tuner, CD, etc.) Do you hear ANY noise or hiss from the speakers at all? I hate to ask, but are the speakers and inputs connected properly? On this model, the jacks are not set up beside each other as they usually are. Instead, the left channel speaker and input jacks are above the right channel jacks. This can be confusing! Are the speakers actually selected? The proper speaker select switch (below the power switch) must be in the down position. Is it possible that someone left a headphone adapter plug in the headphone jack? You know, the kind that allows you to use headphones with a 1/8" plug in that 1/4" jack? This will cause the speakers to be shut off. If you don't have the owner's manual, it's at http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr500_manual_e.pdf If none of this helps, the unit may have a problem and I would invite you to write back with more details on what you've tried, etc.
Jun 10, 2007 | Onkyo TX-SR503 Receiver
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Hum coming out of Front left/right speakers but not center
There is a chance that your wiring is producing this problem. Manufacturers don't always make equipment that is compatible with each other. The biggest problem's are "ground loops". Radio Shack has a non-electrical device that separates the common ground from all equipment. You basically connect it between your amp out's and in's - cables included. It is possible that other manufactures also make and sell this device too. It's main "Google" name would most likely be - "Ground Loop Isolators". If you are using the actually speaker outputs into your subwoofer amp input(s), check your polarity wiring again. Good luck with your system - it sounds like it'll rock when it's all setup correctly.
Nov 06, 2008 | Paradigm PDR 12 Speaker
Speakers
'Buzzing' is not a good thing; it implies that filtration of the DC used by the output section is not as it should be. Power supplies that are mildly overloaded can cause this or an abnormal current drain from one (or more) channels.
The odd problem with the back speakers does sound like a setup problem rather than a circuit failure.
Oct 31, 2008 | Onkyo TX-DS989 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
122 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
