20 Most Recent Sherwood R-945 Receiver Questions & Answers
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Sherwood R-945... | Answered on Sep 08, 2017
I assumed that your receiver has a SUB RCA jack on the back..
find out the SUB output 1xRCA plugs of your receiver on the back and connect it to the 1x RCA input of your Sub...you just need a RCA cable .
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
If you need more help please contact me...with more detailed question..
Regards
Sherwood R-945... | Answered on Jun 22, 2011
Keep pressing VCR1 REC on the unit itself, it's just above the selector switch.
Sherwood R-945... | Answered on Feb 21, 2010
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Sherwood R-945... | Answered on Dec 31, 2009
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Sherwood R-945... | Answered on Nov 10, 2008
The Sherwood R-945 has at least 6 fuses inside - any one of them could keep the system from powering on properly. The lowest power fuse is rated at only 35 MILIamps, I believe ( it's element is barely visible to the naked eye ). Check that all fuses are intact (with the power off)
My R-945 unit kept shutting itself off directly after powering up - turned out that one of the speaker wires had a fault - (found after hours searching with voltmeter). Check that all Inputs / Outputs are secure.
Good luck with yours!
output tranisister is the transister that give the finial output of sound.
some use a output IC for the same purpose.
Sherwood R-945... | Answered on Sep 03, 2008
HAI , REPLACE THE VOLUME CONTROLS.
Sherwood R-945... | Answered on Jun 26, 2008
Most things are fixable even if modifications have to be made in order to use modern components if originals are no longer available.
First you need to find a person with the expertise to fix it and then you have to afford it because these days repairs aren't cheap. Most repair shops no longer offer free estimates and the cost of the estimate alone often exceeds the value of an item.
Salvage yards are full of classic hifi units...
Sherwood Audio... | Answered on Jun 03, 2020
Sherwood R-945 Receiver Logo
Popular Tags
18 questions posted
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rhodesworks
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sherwood Audio Players & Recorders
Most Popular Question
sherwood r 945 receiver optical
  • Audio Players & Recorders
