20 Most Recent Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Questions & Answers
0answers
Program code for RCA converter box remote??
http://www.rcaaudiovideo.com/remote-code-finder/
8/31/2014 5:03:21 AM • Panasonic... • Answered on Aug 31, 2014
How do I reset my Panasoni Triple Play TV
Check this link to download the user manual to this TV. It has some details about how to reset it. If you wish to make a Factory reset, you have to enter its service mode option. For user manual Panasonic PV DM2792 Operating Manual try this ink. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
6/18/2014 3:36:18 PM • Panasonic... • Answered on Jun 18, 2014
Panasonic pv-dm2792 will not turn off closed
You need to turn off closed caption in your source device such as a cable box or satellite receiver.
10/28/2013 1:50:10 PM • Panasonic... • Answered on Oct 28, 2013
Where do i get a remote
Wal-mart, or Dollar Store.
3/31/2013 10:26:02 AM • Panasonic... • Answered on Mar 31, 2013
Set closed caption options
It is done with the remote in the set menu, select closed captions and adjust to what you want, CC1 is most common for the feature but sets will in some cases have auto which if selected when sound is muted the captions come up instantly.
12/23/2012 2:54:30 PM • Panasonic... • Answered on Dec 23, 2012
How do I access the main menu on a panasonic triple play TV without the remote
asking the same question, and before anyone answers, there is no action button on the tv
12/10/2012 6:53:15 AM • Panasonic... • Answered on Dec 10, 2012
How do I accesss the menu without the remote?
in Action botton in tv front.
12/10/2012 6:52:23 AM • Panasonic... • Answered on Dec 10, 2012
Small green light flasing on the front of the tv..think it says programable timer..how to shut it off ?
It is stupid as it serves no purpose at all-----I have removed a few----and several people I know have used a carefully cut piece of black tape to cover it up.
3/24/2012 4:22:33 AM • Panasonic... • Answered on Mar 24, 2012
Is there a universal remote that I can purchase that will control all 3 functions of the set (tv/vcr/dvd) and the cable box? If not all 4, just the 1st 3 would be sufficient.
yes, you can buy that type at most electronics places (Wal-Mart, Radio Shack, etc) for $10-20 USD
3/4/2012 10:50:00 PM • Panasonic... • Answered on Mar 04, 2012
0answers
DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
8/29/2011 11:04:07 PM • Panasonic... • Answered on Aug 29, 2011
All panasonic tv codes
Hi, try these codes out. also make sure that your remote batteries are in the right way.
PANASONIC Codes: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
6/5/2011 6:24:59 AM • Panasonic... • Answered on Jun 05, 2011
2answers
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
6/5/2011 6:05:11 AM • Panasonic... • Answered on Jun 05, 2011
I only see one solid horizontal line on my tv
It lost Vertical sweep either due to open fuse resistor feed the Vertical output circuits, failed vertical/oscillator IC, failed Vertical york (on the neck of the picture tube). Those are what you need to check. This is CRT TV, the repair shop will charge at lest $35 to tell you what I just indicate, to repair it iwll more likely to be in $100 range.
Please leave rating if it helps.
2/1/2011 9:13:03 PM • Panasonic... • Answered on Feb 01, 2011
2answers
Where can I find a book on the different UVerse
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
1/31/2011 1:30:10 AM • Panasonic... • Answered on Jan 31, 2011
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
72 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
all panasonic tv codes
  • Televison & Video
