My cannon 405 showing code e100 pls help me to solve this problem
SOURCE: Cannon GP 405 error code E100, E301, E220
If you have error 301, 100 & 220, just open the cover of camera and clean the camera lens and just remove white strip of the board and clean and replace it, then its works successfully
SOURCE: Canon 405 Problem
when i start copy Error E100 occurs. How do i solve this problem please immediately send me the manual of canon 405 and immediately send me solution of this problem.
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
