Dirt Devil vacuum M85845 broken belts. Can't get more than 1/2 hour on the belt and it breaks. When operating it smells like burning rubber. Am I missing an adjustment?
Call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
your brush roller isn't turning ,its siezed up.take the bottom off and pull the brush roller out.theres probably hair and carpet strands wrapped arond the ends of it.see if you can take the ends off its probably loaded with stuff.after you get the roller cleaned see if the roller turns freely if not then you need a new roller.clean the old rubber off the motor shaft before replacing it with the new one or it on't last very long.the roller is whats causing your belts to burn up
