That means that your belt is worn, stretched or broken. You need to replace the belt. You can get replacement belts and view the manual:
Dirt Devil Dynamite M084600 Belts
Download the Manual (PDF)
A few weeks ago I ran into the same problem, virtually no suction. First I replaced the bad belt (make sure you fit it right or it'll destroy the belt, luckily I bought 2!) and while the vacuum sounded more "alive" it didn't seem to pick up anything any better. The final solution was taking apart the entire intake port section down to the motor and getting the collection tube. It was filled with junk all the way up. I spent over an hour clearing out gunk and animal fur throughout the tubing. Putting it back together was a cinche because the entire vacuum uses one screw type universally. The whole process was pretty intuitive and its clear it's meant to be taken apart for just this purpose.
