20 Most Recent Dirt Devil M085850 Featherlite Bagless Upright VacuumVacuum Questions & Answers
There's a cut wire you need to bring your vacuum to an electrician to fix it before it start a fire.
Dirt Devil... | Answered on Aug 24, 2012
If the belt has melted then there's something obstructing between the brush, belt and dust channel. Check that the endof the brush roll is completely clean, check that the brush roll rolls easily with your hand (obviously don't plug it in or switch it on when repairing/inspecting) If you can locate the motor shaft pin make sure that it rolls easily - if not then the motor may have seized up which will need professional repair. Also check that the filters are clean and the hoses are clear.
Dirt Devil... | Answered on Mar 29, 2011
This is most likely a clogged inlet, clogged hose, or a clogged filter. Just need to inspect it thoroughly and give it a good cleaning.
More info, let me know.
Charlie
Dirt Devil... | Answered on Feb 08, 2011
Even though the belt is intact it can still be stretched or worn and will not turn the brush on the carpet. Here are the belts you need:
Dirt Devil Featherlite Belt
Dirt Devil... | Answered on Apr 08, 2010
Open the collection area and behind the bag you will find a filter, this needs to be cleaned and that should solve the problem
Dirt Devil... | Answered on Mar 24, 2010
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Dirt Devil... | Answered on Apr 29, 2009
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Dirt Devil... | Answered on Apr 08, 2009
Request the manual from Dirt Devil.
Dirt Devil... | Answered 2 days ago
maybe the battery is pooched? ng
Dirt Devil... | Answered on Nov 24, 2020
Onn tv has no sound
Dirt Devil... | Answered on Dec 31, 2019
You'll need a model/part number to be able to figure out what belt you need.
Dirt Devil... | Answered on Oct 29, 2019
Dirt Devil M085850 Featherlite Bagless Upright VacuumVacuum Logo
13 questions posted
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dirt Devil Vacuums
  • Dirt Devil Vacuums
Most Popular Question
everytime turn
  • Vacuums
