Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Belt pulley is broken
I have a dirt devil upright vaccum cleaner. The belt pulley on the motor shaft is broken and missing. So when I put a new belt, the shaft spins without the belt moving, thus heating the belt which eventually breaks.
Posted by craasama on
dave taylor
    Scholar:
  • 78 Answers
Sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Posted on Nov 03, 2009
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Changing the belt
there are 4 screws on the bottom 3 around the grid and 1 towards the back of the bottom plate.lift it off, but make sure you clean the old rubber off the motor shaft or your new belt won't last
Mar 01, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Belt replacement
on the bottom you will see 4 screws.take them out and the bottom plate will come off.before you put the new belt on look at the motor shaft.if you see old rubber on it you need to clean it off or your new belt won't last very long
Aug 22, 2008 | Dirt Devil Featherlight Bagless Upright...
Missing part on motor shaft?
the reason the belts are burning up so quickly is the old rubber from the other belts is still on the motor shaft.clean the shaft down to the polished finish then put on a new belt.make sure your brush roller turns freely .thats the other possiblity.the brush roller might be bad.sometimes hair and dirt get twisted around the ends and keeps it from turning
Jun 28, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
Replacing a belt on a dirt devil vaccuum
That metal rod is probably the motor shaft or pulley. On some of these, the open space between the shaft and top cover is very narrow. You just have to push thru th opening to around the shaft, then put it on the brush roll. Th belt will stretch enough to re-install the brush roll.
Jan 06, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
258 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
