SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
SOURCE: Black lines on the right side
The vertical black line at the right-hand side of the page when the printed document includes an image is a problem with all currently available HP Laserjet 1018, 1020 and 1022 drivers. While waiting for HP to fix the problem (they haven't even acknowledged it yet in their webpage) you can bypass it thus: a) Click on the 'Properties' button. b) Click on 'Finishing' and select 'FastRes1200' (this makes the line narrower). c) Click on 'Basics' and select 'Rotated', i.e. printing the page from bottom to top (this elliminates the line completely, in combination with 'b' above). This is a home-made solution I found after numerous trial-and-error attempts and having downloaded several drivers from the web. As a token respect to all of us who have paid money to buy these printers, I hope HP will soon recognize and solve the problem.
SOURCE: printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
SOURCE: lines across printed pages
Does the line repeat, if so tell me what the distance it between repititions. I need the EXACT measurment in millimeters preferably but inches will do.
SOURCE: hp C3180 printer prints test page every time i turn it on
You were being cheap when you ran out of ink and replaced only the Black Ink Cartridge.
Replace the Color Cartridge and the test page will stop printing when you turn it on.
