So i have a Lexmark x3330, and i keep getting this error message:"Left cartridge incorrect". I tried powering off and on, removing the cartridge and so on. Any suggestions? Thanks in advance.
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
X4850
