Viper Security and Remote Start System (basic install included) Logo
Posted on Oct 10, 2012
Need programming instructions for dei 485m remote
tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 • Car Audio & Video
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
Remote starter instructions
First, locate your valet/programming switch. Once you have located the switch, turn the ignition on, press and release said switch then press and hold. Now, while holding the switch, press the lock button on the remote. the vehicle/alarm should respond with a chirp/horn honk. Release the valet switch, turn the ignition off, test the system.
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Re: Valet keyless entry RPN 473T FCC id: EZSDE1474P Bought this aftermarket fob for my 1999 Chevy Silverado (w/keyless remote) It did not come with programming instructions. Any help obtaining instructions...
The great news is you can program your aftermarket key fob yourself. The most difficult part of this process is locating the little activation button. You have to find your alarm box and follow the wires until you find the programming button.
If you need another aftermarket key fob you can find most models here for a great price: https://www.keylessentryremotefob.com/
Here is a video that will help explain:
1helpful
1100F DEI bypass module on a 2003 sport trac
if nothing else just use the "key in the box" method for bypassing the explorer, only thing is you will loose a key, good luck
I have a 471t model remote starter, it fires up
Could be one of a couple of things. Tach not programmed properly or wire not connected correctly. Or the immobilizer bypass is not programmed or working properly.
Top Viper Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Viper Home Security Expert? Answer questions, earn points and help others
