20 Most Recent DEI Python 1400XP Remote Start/Keyless Entry System Questions & Answers
My car is starting on its own
your system was set by accident for cold weather start, which will start it every 2 or 3 hours and run for 2 or 3 min, good thing about this is it will only run do this for 1 day, or untill the car is started with the key
2/18/2023 10:28:21 PM • DEI Python... • Answered on Feb 18, 2023
2answers
Installing a python 1400xp in a 2004 yukon lx
email sent
4/5/2021 5:44:32 PM • DEI Python... • Answered on Apr 05, 2021
Python 1400XP Remote Start and 08 Dodge Avenger issue
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
1/24/2019 11:46:27 AM • DEI Python... • Answered on Jan 24, 2019
I have a toyota camry station wagon 1995 with I
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
1/23/2019 9:19:16 AM • DEI Python... • Answered on Jan 23, 2019
Python remote start lighting sequence
The automated lighting has ambient light sensors and an electronics package that can cause similar issues when they fail.
2/3/2018 3:09:15 PM • DEI Python... • Answered on Feb 03, 2018
Has anyone ever had the phython 1400xp cause the car to not start either by using the remote or bu just using your cars key? am having trouble with my 2004 Tahoe suddenly not starting trying either w
Properly installed remote starters rarely interfere with normal operation of a vehicle. There can sometimes be an issue with the security module that interfaces with the vehicle anti theft. Although rare it can be diagnosed easily. Most often is the vehicle security system components found to be degrading overtime causing intermittent issues. Passlock, passkey 123, pats, all have their own unique component failure issues.
2/3/2018 3:07:19 PM • DEI Python... • Answered on Feb 03, 2018
Python 1400xp installed by circuit city on a 2004
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
9/15/2017 10:36:11 PM • DEI Python... • Answered on Sep 15, 2017
4answers
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
2/7/2015 8:44:56 PM • DEI Python... • Answered on Feb 07, 2015
AVITAL CAR REMOTE START PROGRAM
At this point in my life, I don't know what I would do with out my car remote. It should be an auto electrician that installs the system. As for the program, I am not sure. You might need to look further into it. Elisa Jed ' http://www.stevemacautoelectrics.com.au/services
7/16/2014 11:21:35 PM • DEI Python... • Answered on Jul 16, 2014
2004 toyota 4 runner dies while driving wont turn over
It sounds like the alternator is bad. Remove it and have it tested before replacing the battery. If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
5/27/2014 3:51:40 AM • DEI Python... • Answered on May 27, 2014
2answers
While driving the engine dies
If engine dies while driving and locks trigger then program your remote not to lock/unlock when turning on/off ignition. My car did that for a while before i figured it out and now my car actually runs 100% better and I've had no problems since.....
5/8/2014 10:12:59 PM • DEI Python... • Answered on May 08, 2014
Where can I get the programming instructions for 1400xp
google it
4/30/2014 5:25:55 PM • DEI Python... • Answered on Apr 30, 2014
Engine wont shut off after vehicle started with remote starter
Tools: 10mm torque wrench Step 1: Find the release bonnet lever or button in the car. Step 2: once the bonnet is open, locate the battery pack. d51cf553-3d95-49c0-b403-95c1c48f9ba5.jpg Step 3: Then locate the negative charge and unplug the connector to the terminal by using your torque wrench. Step 4: Then replug it in and close Start the car up and it should work. Hopefully it works.
1/19/2014 5:06:30 PM • DEI Python... • Answered on Jan 19, 2014
Nustart remote starter wont work
go back to installer for reset guidlines
12/21/2013 2:50:49 AM • DEI Python... • Answered on Dec 21, 2013
Wiring diagram
Here is the link for Python 1400XP Wireing! http://rovertech.clanteam.com/depo/Python/1400xp_install.pdf
12/4/2013 11:24:46 AM • DEI Python... • Answered on Dec 04, 2013
I have a Python 1400xp remote start system that
Year/make/model? Have you checked the reading from your intake air temperature sensor (IAT)?
11/9/2013 3:44:17 PM • DEI Python... • Answered on Nov 09, 2013
Phython demands a a key in the ignition to work.
Sounds like the bypass that was installed when the remote start was done lost programming, if you look under the dash and find some boxes under there reply back with some part #'s and I am sure someone can help you out.
11/4/2013 3:35:56 PM • DEI Python... • Answered on Nov 04, 2013
3answers
I just had the computer
The way I understand your question is your vehicle main computer has been replaced and it is not working properly. Since you say you cannot start it, have them come and get it and do what ever additional programming is required. You cannot do this yourself. If this is a remote start issue and you can start your car with the key, take it back and have them make necessary repairs.
Thanks for your interest in FixYa.com.
7/4/2013 5:44:45 PM • DEI Python... • Answered on Jul 04, 2013
DEI Python 1400XP Remote Start/Keyless Entry System Logo
97 questions posted
Top Directed Electronics Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Directed Electronics Vehicle Parts & Accessories
Most Popular Question
while driving engine dies
  • Vehicle Parts & Accessories
