You need to lock the drums and make sure that the motor and drum does not move too much during the transit as it can cause alignment issues. Make sure that the drum is also transported in the correct position.
It will be fine. The transit bolts are there to protect the springs and dampers from stretching if the machine is tilted or laid on its back during shipping to the seller and delivery to the home.
In use with the transit bolts removed it allow the springs, the shock absorber and the big concrete block to absorb movement as the spin evens out the balance of the clothes with the first part of the spin. It also stops the machine walking across the floor as all of the movement is transferred to to case and feet.
It will be fine, I have done it myself after I moved from one house to another and then didn't do any washing for a week or two.
First of all, make sure you have installed it correctly. Generally speaking, the washing machine purchased online has 4 transport screws at the back, which must be removed! ! ! To prevent the roller from crashing.
Second, the washing machine should be placed flat. If your washing table is inclined or uneven, it will make the washing machine vibrate more and make more noise
new washing machine --under warranty
make sure that you have removed all of the transport locking devices that hold the bowl in place for transport , the machine is level and the bowl is level
if all has been removed call for a warranty check of the problem
The mount system is important to stabilize the tub during transport, if your careful you can move this without them. To prevent damage, you can remove the top, pack the unit with blankets to prevent banging around, and damage to control panel inside. Just be careful and this can be done without damage to the unit.
Good Luck
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
