Will the usual cap repair fix this?
Hello Carl,
That problem could be caused by either bad capacitors on the power supply board or a bad back light bulb in the panel. The first thing to check would be the capacitors on the power supply board. Here is a link with a few pictures of how to dis-assemble the unit and what to look for. The tops of the capacitors should be flat, if they are domed or have any bulging then they need to be replaced. If all of the capacitors look good then it is most likely the back light bulb. This can be replaced by it is much more involved.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
