20 Most Recent Samsung SyncMaster 214T Monitor Questions & Answers
DVI won't work
WOW! I have that monitor too on one of my systems! Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why? I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that... I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO? PLEASE let US know if you found a solution! Anthony
12/15/2017 4:11:08 AM • Samsung... • Answered on Dec 15, 2017
0answers
Monitor keep flashing analog and digital when i
Hi Ichandler422,
This usually happens when the monitor does not recognise that it has been plugged in. Please check that there is either a blue analogue or white digital cable connect to the monitor and the computer.
Thanks. Edge.
6/29/2011 11:17:24 PM • Samsung... • Answered on Jun 29, 2011
Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
8/23/2010 4:58:44 AM • Samsung... • Answered on Aug 23, 2010
Samsung FX2490HD 24" HDTV LED Backlit Widescreen Monitor. Can I factory reset my Syncmaster FX2490HD
It sounds like you are in the Store Demo Mode. Turn it off and see if that fixes it. https://www.manualslib.com/manual/145519/Samsung-Syncmaster-Fx2490hd.html?page=27 Reset
Reset Samsung FX2490HD LS24F9DSM to factory state
monitorsfaq.com https://www.monitorsfaq.com > Factory reset > Samsung How to restore or reset Samsung FX2490HD LS24F9DSM. Reset to its factory state Samsung FX2490HD . How to hard reset monitor. Clear all settings or format. ..
8/7/2023 6:46:52 PM • Samsung... • Answered on Aug 07, 2023
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM • Samsung... • Answered on Jun 19, 2022
How to adjust brightness for samsung syncmaster
5 year old hyjacker, vinay. you forgot to say connected to what? is the screen only dim or dead.? even more important clue. RTM read page PDF 17, ? the OSD screen must work or the monitor is dead http://downloadcenter.samsung.com/content/UM/201205/20120517112305649/SA10-04Eng.PDF base pages https://www.samsung.com/us/support/owners/product/lcd-monitor-a10-series
9/12/2018 10:52:46 AM • Samsung... • Answered on Sep 12, 2018
0answers
0answers
6answers
Model 205. How can I update it to allow Windows 10 to install?
Press the auto key of your monitor to get the best fitted resolution for your window, each monitor has a limited graphic capability of which it is designed. if the production is not ok consult your manufacturer.
7/5/2016 7:23:05 AM • Samsung... • Answered on Jul 05, 2016
0answers
Ls22a350
Be the first to answer 5/15/2015 7:20:27 PM • Samsung... • Posted on May 15, 2015Be the first to answer
Vga connection to the mother board
If your motherboard doesn't have a VGA connection, then that means it most likely does not have an integrated video card. If this is the case, then you will have to purchase and install a video card. It is very easy and your local Best Buy should be a great resource. The geeks there are usually very enthusiastic about explaining how to do it. I use to order from newegg.com, but they have become very commercialized and overpriced, like Best Buy. You can check tigerdirect.com or my favorite Amazon.com. Best Buy will price match any items they sell, including those on Amazon. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_3e83613ef5f2a68b
3/13/2015 12:06:38 PM • Samsung... • Answered on Mar 13, 2015
My Samsung Monitor when turned on it is flashing, can't use computer
you need to give a bit better details as to what is happening
12/4/2014 6:41:26 AM • Samsung... • Answered on Dec 04, 2014
Samsung syncmaster 223bw At first when the monitor
Most new LCD tv and monitors color,brightness,vert.hold, horz.hold,resolution, ect., are all controlled by a single programmed EEPROM, that costs more to replace than a new monitor/tv. You pay for the programming, not the chip.
12/1/2014 3:37:18 PM • Samsung... • Answered on Dec 01, 2014
Monitor black now says no cable hooked up
Change the cable and check.
10/19/2014 8:58:57 AM • Samsung... • Answered on Oct 19, 2014
Samsung SyncMaster 214T Monitor Logo
4 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
dvi work
  • Computers & Internet
