Samsung SyncMaster 214T Monitor Logo
Posted on Jun 29, 2011
Monitor keep flashing analog and digital when i turn it on
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 29, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
38693
Points
22
Hi Ichandler422,
This usually happens when the monitor does not recognise that it has been plugged in. Please check that there is either a blue analogue or white digital cable connect to the monitor and the computer.
Thanks. Edge.
5 Related Answers
Anonymous
  • Posted on Jan 02, 2009
SOURCE: monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Anonymous
  • 1768 Answers
  • Posted on Mar 27, 2010
SOURCE: samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Anonymous
  • 202 Answers
  • Posted on Jul 20, 2009
SOURCE: Hello, My SyncMaster 943BX monitor will
monitor is not getting signal from video card, either the cable monitor or video card is bad.
scramblepad
scramblepad
  • 74 Answers
  • Posted on Aug 02, 2008
SOURCE: syncmaster930b problem
http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Anonymous
  • 8637 Answers
  • Posted on Jan 26, 2009
SOURCE: Analog and Digital.
Your monitor should have come with two cables. One is for analog and the other is for digital and is rectangle. Before turning on the computer connect only the Digital cable to your monitor and the video card on the computer. Most monitors will automatically seance the Digital and operate when you start up the computer. Make sure the monitor is ON when the computer starts. Your manual should have instructions that will help.
DO NOT CONNECT BOTH CABLES UP. Only the one needed.
Hope this helps. Bud
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
2answers
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
1helpful
Digiatal input indicator keep flasing
The flashing digital input for DVD means its digtial input is either not connected or not transmiiting. If yoy still hear the DVD it is probably because you also have the analog cables attached. Is that right?
If you had both attached the receiver would opt for digital over analog but would default to analog if the digital signal was not there.
If you can connect the DVD's digital cable you will get actual 5.1 surround sound from DVD.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
Analog and Digital.
Syncmaster930b problem
Take care
Kevin
1helpful
Monitor
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
