Hp w2207h monitor does get hdmi signal but screen in blank. Putting flashlight to blank screen, however, shows icons are there, just hidden behind blank screen. Is monitor defective? Is there a fix?
The power supply-inverter board is probably at fault. Remove the back cover and locate the standard ac power cord connector. The board that the power input connector is soldered to is your power supply - inverter board. Check the electrolytic capacitors on the board. They probably went bad. A visual inspection is usually enough to find out which ones are bad. They will be either bulging or cracked at the top and leaking fluid. I usually replace all of the capacitors that have the same rating whether they look bad or not. Will save you another repair later. If the caps don't look bad, you can take the board to your local tv repair shop and have the caps checked with a esr tester. It's more accurate and they can be tested with the caps in place. Hope this helps.
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
