Epson R800 printer - When I print on best quality premium photo paper on 4x6 the leading edge appears to pushed through the rollers by about 20mm thus leaving an excessively wide border on the leading edge. The other 3 borders are as normal This does not occurr on normal inkjet paper.
Have you any reasons as to cause and how to remedy, please.?
Thanks in anticipation.
SOURCE: Removal of border on bottom and right side of 8X10 print of color slide.
Hi Sounds like some of your printer settings have changed?
Check print settings and your paper size.
Also check print preview to see if print is different.
If all are OK.
1. Remove both printer cables and switch off printer for at least 1 minute.
2. Remove printer driver from computer control panel/printers
3. Swich off computer
4. Reconnect printer cables
5. Start computer abnd allow it to find printer.
6. Instal driver.
Usually does the trick if all worked OK before!
But if not go to Epson site and download new driver.
Good Luck!
Tinteiros (Ebay)
SOURCE: epson r800 inkjet will not turn on
I leave mine unplugged overnight. Next mornig I plug it in, turn it on and restart Windows. Give it a shot.
SOURCE: i print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
SOURCE: epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Check
the following:
Paper
type
Load
up to
this many sheets
Plain paper
Approximately
120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper
Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do
the following:
1. Gently pull any jammed paper out from the output
tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson
Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus
NX400. Open the scanner, remove the jammed paper and torn pieces, close the
scanner, and turn the Epson Stylus NX400 back on.
I have exactly the same problem. Mac OS 10.5.5.
I have the same problem, but with the trailing edge. Mac OS X 10.5.5.
