Try unplugging your communication cable and turn everything off. Turn everything back on and plug in the cable. If that doesn't work delete the printer from your printer list and re-install it. Usually in this type of scenario it's a communication issue.
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I
set my printer so my printout fits the paper size I am using?
Solution: Use the
recommended Print Area MP240
Printing Area
To ensure the best print quality, the machine allows a margin along each edge
of media. The actual printable area will be the area inside these
margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. ()
Printable area (light blue):
The area where it is possible to print. ()
However, printing in this area can affect the print quality or the paper feed
precisionI have a canon mp - o_area15.jpg>
Note
Borderless Printing
By selecting the Borderless PrintingI have a canon mp - bullet_s.gif can make prints with no
margins.
When performing Borderless Printing, slight cropping may occur at the I have a canon mp - bullet_s.gife the printed image is enlarged to fill the whole page.
For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially
reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced
quality. Use them only for test printing. You I have a canon mp - bullet_s.gifBorderless Printing on
plain paper only when printing from your computer.
Depending on the type of paper, Borderless Printing may reduce the print quality
at the top and bottom edges of the paper or cause these parts to become
smudged.
See A5,
A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter,
Legal.
See Envelopes.
A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
* This pageI have a canon mp - o_darkblue6.jpged only when printing from your computer.
Recommended
printing area
Printable
area
Letter, Legal
Size
I have a canon mp - o_ap_074.jpgr />
8.00 x 10.69 inches / 203.2 x 271.4 mm
LI have a canon mp - o_darkblue4.jpg8.00 x 13.69 inches / 203.2 x 347.6
mm
* This page size can be used onI have a canon mp - o_lightblue5.jpg from your computer.
Recommended
printing area
Printable
area
Envelopes
I have a canon mp - o_area_envelope11.jpgrintable Area (width x height)
European DL*
I have a canon mp - o_darkblue8.jpgches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1
mm
* Envelopes can be used only when printing from your computer.
Recommended
printing area
