I Have bought some compatible ink cartridge's for my lexmark x3470. i just get a low ink message. Now the ink doe's work great. But when i try to do some printing work from my computer it gives me the error sign Low Ink and wont print as it says empty or low ink
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
SOURCE: Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
SOURCE: Lexmark x5470 all in one printer-low ink level
This is the problem because Lexmark cart have inbuild sensor , to by pass is to use original lexmark cart .
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
SOURCE: Lexmark x4650 says "print cartridge missing" but just replaced.
CLick on Start, printers and faxes, right click on your printer icon, click on properties.
There should be a tick box to allow you to reset the cartridges to new....
For the most optimal output experience with your AIO, Lexmark
recommends that customers update their firmware. The firmware helps ensure that
customers receive the highest yields of ink available from the cartridges,
which offers the greatest value and means fewer necessary cartridge
replacements.
If you choose to upgrade firmware, note that unauthorized use of
third-party 'cloned' cartridges will no longer be possible.
When purchasing ink cartridges, Lexmark customers have two
options:
Regular ink cartridges without license terms (100A/100XLA) that
you may a) return to Lexmark free of charge (for recycling by Lexmark), b)
refill, recycle or remanufacture themselves, or c) provide to third parties for
refilling, recycling, or remanufacturing. Any Regular ink cartridge
can be refilled by a customer or a third party and will continue to work in
their Lexmark printer.
Return Program ink cartridges that provide customers with an up-front discount in exchange for their agreement to use the ink cartridge once and return it only to Lexmark for remanufacturing and recycling.
replacements.
options:
Regular ink cartridges without license terms that
they may a) return to Lexmark free of charge (for recycling by Lexmark), b)
