20 Most Recent Lexmark X6650 4-In-One Wireless InkJet Printer Questions & Answers
Ensure the software for the mac is installed and follow the prompts.
Lexmark X6650... | Answered on Jun 20, 2017
Please contact Lexmark Technical Support and let them know that you need two replacement cartridges for the two defective ones you have.
Make sure that you purchased factory new Lexmark cartridges, not cartridges that have been refilled and repackaged by a third party company.
Don
Lexmark X6650... | Answered on Apr 17, 2017
You should be able to assign Abby FineReader 11 Pro as the OCR software in the Lexmark software (Lexmark Productivity Studio for Windows or All-in-One Center for the Mac OS). You will need this software though and to have the monitor running to "listen" for the scan button to be pressed. You will also need to ensure your firewall doesn't block communication if you connect the X6650 through the network.
In the Productivity Studio (launch Lexmark Home), click on the Settings tab and then the Scan Destinations option. Add Abby FineReader 11 Pro to the list of destinations. Click on that option and click on the Modify button to make sure that the Application button is set and is pointing to the correct program and correct file type. Then you can go back to the all-in-one and press the Scan button. Select Scan to Computer and then choose Refresh to update the list of destination programs.
I hope this helps. The steps may be slightly different in the Mac software.
Lexmark X6650... | Answered on Oct 17, 2015
You can download the Lexmark user manual and printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark X6650... | Answered on Jul 12, 2014
Your Lexmark scanner may not be able to scan legal size documents (8-1/2 x 14)
Lexmark X6650... | Answered on Jul 09, 2014
Try your printer setting for clean cartridge. Doing it will cost a little ink but it usually solves the problem.
Lexmark X6650... | Answered on Jan 08, 2014
http://pdftransformer.abbyy.com/trial
you can download the trial of this software ...
Lexmark X6650... | Answered on Nov 11, 2013
mohon bantuan gan cara masuk safe modenya gan
Lexmark X6650... | Answered on Sep 15, 2013
This is a problem I've seen with Dell PCs, what it is doing is trying to boot from the card reader on the printer. My PC had this problem, and a Dell BIOS upgrade fixed it. It would even try to boot from USB keys or mp3 players I left in the USB slot! So I have a feeling you have the same problem I had.
If you don't feel comfortable updating the BIOS, then contact Dell and maybe they can walk you through it.
Lexmark X6650... | Answered on Mar 16, 2013
All faxes automatically go into the memory of the printer. If you want to clear the faxes out of the memory, try resetting the printer to its factory defaults.
Lexmark X6650... | Answered on Dec 12, 2012
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Lexmark X6650... | Answered on Dec 10, 2012
Make sure that you're using genuine Lexmark cartridges. If you are, unplug the power adapter of the printer and plug it back in after 20 seconds.
If it doesn't help, reset your printer back to its factory settings:
1Turn off the printer. NOTE: Make sure the printer is not in Power Saver mode. Press and hold pattlnk_732009_107-on.png for two seconds to turn off the printer. If you have set the Power Saver timeout in the Setup menu, press and hold pattlnk_732009_107-on.pngaccording to the time you set in the menu. 2From the printer control panel, press and hold pattlnk_732009_108-green.pngand pattlnk_732009_109-x.png , and then press pattlnk_732009_107-on.png to turn
Lexmark X6650... | Answered on Nov 02, 2012
Hello. Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug the printer back to the power source. When it's still making the clicking sound, check inside of the printer for anything out of the ordinary inside it (loose strips, loose belt or springs, etc.). When you have any of these, call Lexmark. They may be able to send you a replacement. Hope your printer is still within warranty. Clear it from foreign objects. If not making any noise, re-insert the cartridges. If noise starts again, it may be caused by the cartridges not being seated properly. These are the troubleshooting steps you can do to determine what the problem is. If none of these resolves the problem. I advise you to call Lexmark. Hope I can assist you more with this. Good luck!
Lexmark X6650... | Answered on Oct 17, 2012
You would need to install our LexPrint app to your iPad and our LexPrint Listener to your host computer. Go to this URL for more info: http://bit.ly/KY8eCI
Lexmark X6650... | Answered on Sep 11, 2012
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
230 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
  • Office Equipment & Supplies
