20 Most Recent AEG Santo 7388 KG Side by Side Refrigerator Questions & Answers
0answers
Aeg freezer getting hot on the sides
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
5/12/2012 2:58:12 AM • AEG Santo 7388... • Answered on May 12, 2012
3answers
Hello. Please could you tell me where the thermostat is on an AEG Santo fridge freezer model n71 840?
May not be the thermostat. Could be the fan motor.
5/19/2022 4:16:35 AM • AEG... • Answered on May 19, 2022
Temperature of my AEG Arctis freezer started rising for no reason.
sorry but only a local repair service can help you
9/19/2021 11:57:35 AM • AEG... • Answered on Sep 19, 2021
Arctis 3100. Why isn't it freezing?
There must be a gas leakage due to which the refrigerator is not cooling. Better call a technician to fix it.
2/17/2021 6:28:27 PM • AEG... • Answered on Feb 17, 2021
2answers
My AEG freezer works fine but the fridge doesn't seem to cool
Possibly evaporator fan not working or defrost problem.
5/29/2020 4:04:38 AM • AEG... • Answered on May 29, 2020
My aeg inbuilt frost free fridge freezer is collecting ice under the bottom freezer compartment. how can I stop this happening
Sounds like the drain pan or tube is frozen and clogged You need to shut off the unit and empty the freezer section and check the bottom of the rear wall of the freezer for the drain pan. use sink hot water to defrost and a turkey Baster to clean the hole and the hose.
6/20/2019 12:01:26 PM • AEG... • Answered on Jun 20, 2019
Freezer does not freezer does not work on an age fridge freezer
no gas or faulty compressor not worth repairing
2/2/2019 9:54:49 PM • AEG... • Answered on Feb 02, 2019
I have an AEG SANTO OKO fridge unit only about 1 year old. We just cannot open the door without it being pulled 2 inches on every open. I have since placed it on a rubber mat with no success
You have very good door-seals, with strong magnets on the refrigerator. I suspect, You must pull hard to open the door. Does the fridge have 2 wheels? It may only stand firm on 2 "legs" and not 4. This problem is the first, I ever heard, I do not know this model, If it is a Refrigerator that is not very heavy, this can happen. When the door seals are very good, what can happen is The door has been closed and the air inside the fridge becomes cooler and cooler. The air inside the food-compartment contracts, because it cools down and pulls even more on the inside of the door surface, actually pulling the door shut. ( a negative air-pressure inside the fridge) compared to the outside of the refrigerator. A trick I am using is, 1.) I place my finger between the door and the cabinet-frame. 2.) Then, with the finger, index or middle finger, I push gently against the Door-Seal (Gasket). for 1 or 2 seconds, This allows the Air from outside, (higher pressure) to flow into the food compartment of the fridge and now it is easy to open the door. Let me know if this works for you. Appreciate to be alive and be kind to others. Klaus (Electrical & Refrigeration Technician) Toowoomba, AUS
2/6/2018 11:14:37 PM • AEG... • Answered on Feb 06, 2018
0answers
AEG Santo 7388 KG Side by Side Refrigerator Logo
9 questions posted
Top AEG Refrigerators Experts
kelly
kelly
David Spradling
David Spradling
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
AEG Refrigerators
  • AEG Refrigerators
Most Popular Question
aeg freezer getting hot sides
  • Refrigerators
